Quick question about cutting PSU cables
I am currently building in a Sugo sg09 and I'm using a Corsair H80i. The H80i needs a sata power connector to power the pump, so I would only need one more sata power connector.
I have an HX850 semi modular PSU. Since I only need one more sata power, could I cut the rest of the cable off and put heatshrink on the ends to keep them from touching, or would I ruin the whole cable and destroy my pc?
I have one pic of the cable, and one showing in red where I want to cut and marked in red the part I want to cut away.
So does anyone know if this would work or not?
Thanks for any help, I'm not very good at the laws of electricity.
-Dovin
You cutting off the connectors/wires that you don't need and then correctly terminating the wires, would do as much damage to the PSU as leaving them there and not plugging any drives/pumps/whatever into those last three connectors. Comprende? Do it right and you're fine
