Pin Navigation?
Go to solution Solved by Techicolors,
it just follows the screen when you scroll up or down.
unpin it and it will stay at the top, so you have to scroll all the way up to see it
As already stated, if you have it pinned, the top bar will follow you as you scroll up or down.
https://linustechtips.com/topic/538222-pin-navigation/#findComment-7134513
