Are you running on the stock cooler for the FX 9370?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/538120-blue-screen-need-help/#findComment-7133516
On 31/01/2016 at 2:10 PM, Reece Leu said:
What is the blue screen error message?
How often does it happen, and when does it happen?
Check device manager for any undetected devices.
Check the event view for logs.
im not sure and not quite often recently but yeah and ok will do and where do i find the logs?
https://linustechtips.com/topic/538120-blue-screen-need-help/#findComment-7146549
