Print Screen problem
Go to solution Solved by DennisBerry,
Maybe because the directory you want to save the file in, is read only? Right click on the map where you want to save it and uncheck the read only box. You upgraded from windows 7 to windows 10? If so i had the same problem. It has something to do with adminitrator rights.
CPU: Intel i5 6600 @ 3.3GHz (Boost 3.9GHz) | Motherboard: ASUS Skylake Z170-K | RAM: Kingston HyperX FURY 16GB DDR4 @ 2133MHz GPU: ASUS GeForce STRIX GTX970 OC 4GB | SSD: Samsung 850 EVO 500GB + 250GB | PSU: Cooler Master GM Series G650M | Case: Cooler Master CM 690 III (side window)
https://linustechtips.com/topic/537431-print-screen-problem/#findComment-7127227
Okay so I print screened a picture put it wont let me save it, it says "you cant save here, please use another location" like what, I have 900Gb of storage left in my hard drive, what.
I have Windows 10
If you have a USB stick then try that
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/537431-print-screen-problem/#findComment-7127232
no I didn't upgarde
https://linustechtips.com/topic/537431-print-screen-problem/#findComment-7128026
