Ok so i was removing my hp probook 4530s battery above my desk and it fell 5-10cm onto my hard plastic desk. Im worried bc li-ion batteries are volatile but i havent plugged it back in. Will at that distance with no cracks or chips on the battery casing, it be ok to continue to use and am i just overreacting.
R5 5600   Asus ROG Strix RTX2060   B550  Crucial Ballistix 16GB DDR4   Kingston A2000 1TB M.2    Kingston UV400 SSD   NZXT H510 Flow
https://linustechtips.com/topic/537341-dropped-laptop-battery/
VERY unlikely it did anything. They can take a pretty serious impact in those battery cases. I would be worried at a couple meters or so.
https://linustechtips.com/topic/537341-dropped-laptop-battery/#findComment-7126150
honestly, dont worry til you see chips and stuff or it starts to expand
you are overreacting a lot actually
https://linustechtips.com/topic/537341-dropped-laptop-battery/#findComment-7126155
Post a photo of the battery.  if it's covered by a hard plastic case, as most removable laptop batteries are, there is no problem.  In order to actually damage the lithium cells inside the external plastic case has to be seriously dented.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/537341-dropped-laptop-battery/#findComment-7126157
