I need a quick help with a build for a friend.
i Brainstormed that he should take like an:
i5-6600 CPU
some kind of SSD
R9 390 or gtx 980 GPU (depending on money left)
DDR4 8GB
These are the main parts, other ones i'll sort out.
Pc will be used for gaming
Thank you.
i5-4690k, R9 380 4gb, 8gb-1600MHz ram, corsair vs 550w, astrock h97m anniversary.
https://linustechtips.com/topic/537245-1000eu-pc-build-suggest/
I personally would go for Haswell in this build.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/537245-1000eu-pc-build-suggest/#findComment-7125110
i5 or i7?
of course pc should be used at least 5years with good performance
i5 4460 or some K edition, Skylake is overpriced for now , Intel is not making enough for the demand.
https://linustechtips.com/topic/537245-1000eu-pc-build-suggest/#findComment-7125179
Not really and i5-4690k cost 250eu and i5-6600 240eu
You pay for the k. does he/she wanna overclock? Of course it depends on region so if you get a good deal on skylakes, go for them. Just know the IPC increase is pretty small.
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
https://linustechtips.com/topic/537245-1000eu-pc-build-suggest/#findComment-7125226
