Hi guys,
So I noticed that the zip tie has cut through the little blue cable on my D5 pump the one that has the fan connector at one end, I never used this cable so had it tied up behind the motherboard tray as I always use the molex connector on the other cable on the pump.
Does it matter that this cable has snapped and is it safe to cut it off completely now as I don't think I can put the connector back on the end.
I assume this is just so you can control the pump through the bios fan curves and such?
The pump is a vario style one with settings 1 to 5 which is generally what I use to set the speed.
Thanks
Custom PC:
Intel Core i7 5960X GTX1080 Strix | 64gb 2400mhz DDR4 Corsair Vengeance Ram | Samsung S951 256gb M.2 | 4TB WD Blue SSHD | EVGA Supernova G2 1300watt PSU | Acer XB270HU | Corsair K95 RGB | Corsair M65 RGB |
https://linustechtips.com/topic/536425-snapped-cable-to-pump/
Hi guys,
Thanks
It just senses the rpm as far as I know. I've got a D5 vario as well and have never used that cable.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/536425-snapped-cable-to-pump/#findComment-7115330
So I can pretty much just leave it chopped off? I didn't think it was anything to worry about just wanted to check lol I will try not to do cable ties so tight in future I only noticed it as I am changing motherboard and got a new glass cylinder res from XSPC called the photon 170 (I think thats what they call it)
Custom PC:
https://linustechtips.com/topic/536425-snapped-cable-to-pump/#findComment-7115354
If you want I guess, if you've got zero need for it then just leave it as it is. My other system required a signal for one of the CPU pwm connectors and I just plugged it to that so I didn't get this stupid error on start up.
https://linustechtips.com/topic/536425-snapped-cable-to-pump/#findComment-7115385
You can disable that error within the bios on most motherboards, I use to get that error on my old Asus motherboard when I used a water cooler with it said something along the lines of "Error CPU fan not detected" but it might depend on brand of motherboard MSI ones don't seem to do it at all. At the moment my new motherboard is being RMA'd due to a Debug code bd so I'm in the process of deciding whether to get it refunded and get the Asus Rampage Extreme x99 or getting a refund selling my 5960X and moving over to the z170 & 6700k but I hope to have my PC back soon my old PC can only handle titles such as dying light on medium due to Vram limitations.
Custom PC:
https://linustechtips.com/topic/536425-snapped-cable-to-pump/#findComment-7115408
Hi PeggersXtreme, all the blue cable does is send an rpm signal. I have it hooked up so my system shuts down if the pump fails. You can cut it of if you want too, you will just loose out on rpm readings you werent using eitherway
https://linustechtips.com/topic/536425-snapped-cable-to-pump/#findComment-7122127
