So i want to upgrade my graphics card from a AMD Radeon™ R7 200 Series to a MSI Radeon R9 390 Gaming 8GB. I was wondering if my power supply provides enough power or i need to upgrade it. Also wondering things like will it fit in the case or not? And lastly will my pc be bottlenecking or not. Any help would be greatly appreciated, Thanks in advanced! <3
Current setup:
CPU: Intel core i5 4670k
Motherboard: MSI b85m-e45
RAM: 8GB Corsair (2x 4GB Sticks)
GPU: AMD Radeon™ R7 200 Series (http://imgur.com/HR4VLNE)
Case: Cooler Master Storm Scout II Advanced
Storage: 1 Terabyte Western Digital Blue
PSU: Corsair CX 500W
https://linustechtips.com/topic/536336-need-help-upgrading-my-pc/
Is that a CX?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Ya, exact PSU model
and what's your exact GPU model? Because if it's like a 270 or higher, it's probably not worth it, especially if you have a 1080p display only
Im not very good at pc's what is a cx?
He meant if it's a CX series PSU (as in the name).
E.g. CX500, CX600...
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
CX is a name of a popular power supply made by corsair.
If you open your side panel what is written on it, there is dozens of power supplies made by crosair.
Current setup:
PSU: Corsair 500Watts
What gpu and psu exactly?
Ya, exact PSU model
All i can see is that it is a r7 200 series http://imgur.com/HR4VLNE, And im not asking if it is worth i'm asking whether i can or not because i want to be able to play video games at 1080p ultra which i currently cannot ( BF4, Far cry 4, Fallout 4)
You need speccy
https://www.piriform.com/speccy
your PSU is fairly average, so something like a 380 should be fine, 390 should be good as well, but that's going to be at about the upper limit
You need speccy
Thanks alot :D ! I dowloaded specky and it litterly just said my grahics card was a "r7 200 series" aswell.
Okay, well if you have the newest drivers installed, open that up and under system hit where it says hardware
You need speccy
I´d say it´s a little below avg., but that´s just me. I personally wouldn´t go above 380, and that´s pushing it IMO.
