Yes, it runs at lower temperatures so it allows for overclocking and the bigger the heat sink the slower the fans have to spin which reduces noise.
https://linustechtips.com/topic/536050-heat-sinks/#findComment-7110616
bigger the heatsink the better heat dissipation which equals lower temps and lower fan speeds which equals happy cpu and happy ears
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/536050-heat-sinks/#findComment-7110658
>Title: Heat Sinks
No, heat rises. That's why the bigger the heatsink above your CPU, the more heat can be dissipated.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/536050-heat-sinks/#findComment-7112302
