Nice cable management, and make sure the side pannel window (if it has one) is scratch free.
Also wipe down the outside of the case too.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/536013-cleaning-my-pc/#findComment-7110260
Its a C70 i have, the window has one very small, barely visable scrape in the top corner of it, facing the window it has a small paint chip on the hinge, nothing major. Apart from that it has nothing else wrong with it, cable management below...
https://linustechtips.com/topic/536013-cleaning-my-pc/#findComment-7110379
This, making the outside of the case look nice is a good thing to start with as its the first thing people look at. Making the inside cables all tidy and hidden is also a good thing to do, especially if there is a side panel window. If you can try and make the back where all the cables are tidy too though that isn't as important as its not often seen. A good microfibre cloth will go along way on the outside.
This may not be a popular opinion but I use a soft non conductive plastic paintbrush to clean all the inside of my computer but make sure you don't press down hard so you don't damage anything.
Edit: From pictures supplied the cable management doesn't look too bad personally so just make sure its fairly dust free both outside and in :)
[Insert Signature Here]
https://linustechtips.com/topic/536013-cleaning-my-pc/#findComment-7110391
I will edit this post with a picture of the back of the pc with side panel off.
https://linustechtips.com/topic/536013-cleaning-my-pc/#findComment-7110430
How can i upload my picture? i have it on my pc but i don't know how to post it, i done it before on the show off your build but i don't know how to do it now :/
https://linustechtips.com/topic/536013-cleaning-my-pc/#findComment-7110565
Alcohol wipes. Use non latex gloves and clean the case with alcohol wipes, it not only gets the dust off but fingerprints and smudge marks as well. But if you decide to do this make sure you do it in small segments. Wipe an area then wipe again with preferably a microfiber towel. If you don't it will cause a foggy look.
https://linustechtips.com/topic/536013-cleaning-my-pc/#findComment-7111185
