Hi, I am currently using a HP XW6600 workstation, with windows server 2008 r2 on it and my ram is not giving me a very nice temperature. Any advice is appreciated. (temp in pic)
> Link to the workstation > h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3463353〈=en&cc=uk
> Some basic specs:
* 2x4GB RAM modules
* 2x Xeon CPUs
* fan cooling DIRECTLY over RAM
* no OS's installed other than 2008 r2
* old af BIOS with no upgrade-ability
Oh and the workstation is for use of a Dedicated Arma 3 servers.
post-261206-0-42339200-1453931661_thumb.
https://linustechtips.com/topic/535973-help/
Place a fan on the ram?
Is the high temp a problem?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/535973-help/#findComment-7109737
There are two fans over the ram, and i have to remove the fans to get to the RAM.
your link to the workstation doesnt work.
But i highly doubt that there are two *working* fans and it's still that high. Or the readings are off. Just try to touch it and see how hot it gets
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/535973-help/#findComment-7109814
