Alright, so I know you all have seen way too many questions on the topic of chemistry, but here's one more for you all:
So we did a lab and I am completely lost on what to do next. We have to find the chemical equation that represents the decomposition of sodium bicarbonate (NaHCO3) and we are given a choice between:
2NaHCO3 --> Na2CO3 + CO+ H2O
or
2NaHCO3 --> Na2O + 2CO2+ H2O
I am looking at the solids, the first product, Na2O or Na2CO3, and fount that Na2O is .023 moles and Na2CO3 is .012 moles from our 1.42g of precipitate. Any ideas of what to do from here? Do you need any more information?
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/535759-chemistry-help/
both are wrong
Use upper and lower case T_T
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107241
This topic reminds me why i almost failed chemistry in elementary. Barely passed.
Lenovo/IBM ThinkPad T61 Widescreen 15.4" 1680x1050
Intel Core2Duo T8300 2.4GHz | 3GB DDR2 from Hynix | SATA II Patched bios (Middleton) | Samsung EVO 850
Arch Linux | Linux 4.3.X x86_64
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107242
2NaHCO3 --> Na2O + 2CO2 + H2O
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107246
2NaHCO3 --> Na2CO3 + CO2 + H2O
or
You should be using Open Study or Peer Answer.
  "As Individuals we are weak like twigs but when we come together we become a mighty faggot"
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107281
how were you able to get the subscripts?
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107324
The forum has it built in :D - above the text field
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107346
Thanks, edited op
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107379
Well the second one is what happens, but to derive that from your experimental results you should calculate the amount of substance of the sodium bicarbonate you started with. Then you can compare that number to the numbers you calculated for sodium carbonate or sodium oxide as product.
https://linustechtips.com/topic/535759-chemistry-help/#findComment-7107545
