I have a R9 290 with modded with a Deepcool Maelstrom 240T , OCed GPU temps are 65 oC but the VRMs can get over 105 oC
I wonder if I can add an EK block to the AIO loop like this
AIO Pump + block on CPU > vga block > radiator
my CPU is i5 4460 0.91V 55 oC gaming (plan to upgrade to 1230V3)
will the aio pump be sufficient?
the pump spec: 2.4W - 2200rpm
https://linustechtips.com/topic/535634-fullboard-gpu-block-aio-pump-possible/
you can always try to ghetto it in but I wouldn't think the AIO pumpt will be enough, especially for the custom GPU waterblock
instead look at Alphacool Universal GPU blocks
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
i don't think a 240mm rad could actually take the heat of both a CPU and 290 and dissipate it effectively, especially if you plan to OC/keep it OCed. EDIT:Reread it, do you mean to bassically create a sortof AIO solution for just the GPU?
you might be able to make up you own solution, possibly using similar solutions for RAM watercooling like these:
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
I just worry about the vrm temps. If set to 1170mhz @ +100mv vrms will get to 116 oC. And there is 2 fans blowing to the board 4cm away as you can see in the picture. I hate to know that I can't game at 1170mhz even when my gpu and gpu temps allow it
