#include<fstream.h>
#include<conio.h>
#include<stdio.h>
#include<process.h>
#include<string.h>
#include<iomanip.h>
//                   CLASS USED IN PROJECT
class book
    char bno[6];
    char bname[50];
    char aname[20];
  public:
    void create_book()
        cout<<"\nNEW BOOK ENTRY...\n";
        cout<<"\nEnter The book no.";
        cin>>bno;
        cout<<"\n\nEnter The Name of The Book ";
        gets(bname);
        cout<<"\n\nEnter The Author's Name ";
        gets(aname);
        cout<<"\n\n\nBook Created..";
    void show_book()
        cout<<"\nBook no. : "<<bno;
        cout<<"\nBook Name : ";
        puts(bname);
        cout<<"Author Name : ";
        puts(aname);
    void modify_book()
        cout<<"\nModify Book Name : ";
        gets(bname);
        cout<<"\nModify Author's Name of Book : ";
        gets(aname);
    char* retbno()
        return bno;
    void report()
    {cout<<bno<<setw(30)<<bname<<setw(30)<<aname<<endl;}
};         //class ends here
class student
    char admno[6];
    char name[20];
    char stbno[6];
    int token;
public:
    void create_student()
        clrscr();
         cout<<"\nNEW STUDENT ENTRY...\n";
        cout<<"\nEnter The admission no. ";
        cin>>admno;
        cout<<"\n\nEnter The Name of The Student ";
        gets(name);
        token=0;
        stbno[0]='/0';
        cout<<"\n\nStudent Record Created..";
    void show_student()
        cout<<"\nAdmission no. : "<<admno;
        cout<<"\nStudent Name : ";
        puts(name);
        cout<<"\nNo of Book issued : "<<token;
        if(token==1)
            cout<<"\nBook No "<<stbno;
    void modify_student()
        cout<<"\nModify Student Name : ";
        gets(name);
    char* retadmno()
        return admno;
    char* retstbno()
        return stbno;
    int rettoken()
        return token;
    void addtoken()
    {token=1;}
    void resettoken()
    {token=0;}
    void getstbno(char t[])
        strcpy(stbno,t);
    void report()
    {cout<<"\t"<<admno<<setw(20)<<name<<setw(10)<<token<<endl;}
//        global declaration for stream object, object
fstream fp,fp1;
book bk;
student st;
//        function to write in file
void write_book()
    char ch;
    fp.open("book.dat",ios::out|ios::app);
    do
        clrscr();
        bk.create_book();
        fp.write((char*)&bk,sizeof(book));
        cout<<"\n\nDo you want to add more record..(y/n?)";
        cin>>ch;
    }while(ch=='y'||ch=='Y');
    fp.close();
void write_student()
    char ch;
    fp.open("student.dat",ios::out|ios::app);
    do
        st.create_student();
        fp.write((char*)&st,sizeof(student));
        cout<<"\n\ndo you want to add more record..(y/n?)";
        cin>>ch;
    fp.close();
//        function to read specific record from file
void display_spb(char n[])
    cout<<"\nBOOK DETAILS\n";
    int flag=0;
    fp.open("book.dat",ios::in);
    while(fp.read((char*)&bk,sizeof(book)))
        if(strcmpi(bk.retbno(),n)==0)
            bk.show_book();
             flag=1;
    fp.close();
    if(flag==0)
        cout<<"\n\nBook does not exist";
    getch();
void display_sps(char n[])
    cout<<"\nSTUDENT DETAILS\n";
    int flag=0;
    fp.open("student.dat",ios::in);
    while(fp.read((char*)&st,sizeof(student)))
        if((strcmpi(st.retadmno(),n)==0))
            st.show_student();
            flag=1;
    fp.close();
    if(flag==0)
            cout<<"\n\nStudent does not exist";
     getch();
//        function to modify record of file
void modify_book()
    char n[6];
    int found=0;
    clrscr();
    cout<<"\n\n\tMODIFY BOOK REOCORD.... ";
    cout<<"\n\n\tEnter The book no. of The book";
    cin>>n;
    fp.open("book.dat",ios::in|ios::out);
    while(fp.read((char*)&bk,sizeof(book)) && found==0)
            bk.show_book();
            cout<<"\nEnter The New Details of book"<<endl;
            bk.modify_book();
            int pos=-1*sizeof(bk);
                fp.seekp(pos,ios::cur);
                cout<<"\n\n\t Record Updated";
                found=1;
        fp.close();
        if(found==0)
            cout<<"\n\n Record Not Found ";
        getch();
    char n[6];
    int found=0;
    clrscr();
    cout<<"\n\n\tMODIFY STUDENT RECORD... ";
    cout<<"\n\n\tEnter The admission no. of The student";
    cin>>n;
    fp.open("student.dat",ios::in|ios::out);
    while(fp.read((char*)&st,sizeof(student)) && found==0)
        if(strcmpi(st.retadmno(),n)==0)
            st.show_student();
            cout<<"\nEnter The New Details of student"<<endl;
            st.modify_student();
            int pos=-1*sizeof(st);
            found=1;
    fp.close();
    if(found==0)
    getch();
//        function to delete record of file
void delete_student()
    char n[6];
    int flag=0;
    clrscr();
        cout<<"\n\n\n\tDELETE STUDENT...";
        cout<<"\n\nEnter The admission no. of the Student You Want To Delete : ";
        cin>>n;
        fstream fp2;
        fp2.open("Temp.dat",ios::out);
        fp.seekg(0,ios::beg);
        if(strcmpi(st.retadmno(),n)!=0)
                 fp2.write((char*)&st,sizeof(student));
        else
               flag=1;
    fp2.close();
        fp.close();
        remove("student.dat");
        rename("Temp.dat","student.dat");
        if(flag==1)
             cout<<"\n\n\tRecord Deleted ..";
        else
             cout<<"\n\nRecord not found";
        getch();
void delete_book()
    char n[6];
    clrscr();
    cout<<"\n\n\n\tDELETE BOOK ...";
    cout<<"\n\nEnter The Book no. of the Book You Want To Delete : ";
    cin>>n;
    fstream fp2;
        if(strcmpi(bk.retbno(),n)!=0)
            fp2.write((char*)&bk,sizeof(book));
    fp2.close();
        fp.close();
        remove("book.dat");
        rename("Temp.dat","book.dat");
        getch();
//        function to display all students list
void display_alls()
    clrscr();
         if(!fp)
               cout<<"ERROR!!! FILE COULD NOT BE OPEN ";
               getch();
               return;
    cout<<"\n\n\t\tSTUDENT LIST\n\n";
    cout<<"==================================================================\n";
    cout<<"\tAdmission No."<<setw(10)<<"Name"<<setw(20)<<"Book Issued\n";
        st.report();
    fp.close();
    getch();
//        function to display Books list
void display_allb()
    clrscr();
    if(!fp)
               getch();
               return;
    cout<<"\n\n\t\tBook LIST\n\n";
    cout<<"=========================================================================\n";
    cout<<"Book Number"<<setw(20)<<"Book Name"<<setw(25)<<"Author\n";
        bk.report();
         fp.close();
         getch();
//        function to issue book
void book_issue()
    char sn[6],bn[6];
    int found=0,flag=0;
    clrscr();
    cout<<"\n\nBOOK ISSUE ...";
    cout<<"\n\n\tEnter The student's admission no.";
    cin>>sn;
        fp1.open("book.dat",ios::in|ios::out);
        if(strcmpi(st.retadmno(),sn)==0)
            found=1;
            if(st.rettoken()==0)
                      cout<<"\n\n\tEnter the book no. ";
                cin>>bn;
                while(fp1.read((char*)&bk,sizeof(book))&& flag==0)
                       if(strcmpi(bk.retbno(),bn)==0)
                        bk.show_book();
                        flag=1;
                        st.addtoken();
                        st.getstbno(bk.retbno());
                        cout<<"\n\n\t Book issued successfully\n\nPlease Note: Write current date in backside of book and submit within 15 days fine Rs. 1 for each day after 15 days period";
                  if(flag==0)
                        cout<<"Book no does not exist";
                else
                  cout<<"You have not returned the last book ";
          if(found==0)
        cout<<"Student record not exist...";
    getch();
      fp.close();
      fp1.close();
//        function to deposit book
void book_deposit()
    char sn[6],bn[6];
    int found=0,flag=0,day,fine;
    clrscr();
    cout<<"\n\nBOOK DEPOSIT ...";
    cout<<"\n\n\tEnter The student’s admission no.";
    cin>>sn;
            found=1;
            if(st.rettoken()==1)
               if(strcmpi(bk.retbno(),st.retstbno())==0)
                bk.show_book();
                flag=1;
                cout<<"\n\nBook deposited in no. of days";
                cin>>day;
                if(day>15)
                   fine=(day-15)*1;
                   cout<<"\n\nFine has to deposited Rs. "<<fine;
                    st.resettoken();
                    cout<<"\n\n\t Book deposited successfully";
          if(flag==0)
         else
            cout<<"No book is issued..please check!!";
      if(found==0)
    getch();
  fp.close();
  fp1.close();
//        INTRODUCTION FUNCTION
void intro()
    clrscr();
    gotoxy(35,11);
    cout<<"LIBRARY";
    gotoxy(35,14);
    cout<<"MANAGEMENT";
    gotoxy(35,17);
    cout<<"SYSTEM";
    cout<<"\n\nMADE BY : Amit Dutta";
    cout<<"\n\nSCHOOL : Kendriya Vidyalaya No.1 Ishapore";
    getch();
//        ADMINISTRATOR MENU FUNCTION
void admin_menu()
    clrscr();
    int ch2;
    cout<<"\n\n\n\tADMINISTRATOR MENU";
    cout<<"\n\n\t1.CREATE STUDENT RECORD";
    cout<<"\n\n\t2.DISPLAY ALL STUDENTS RECORD";
    cout<<"\n\n\t3.DISPLAY SPECIFIC STUDENT RECORD ";
    cout<<"\n\n\t4.MODIFY STUDENT RECORD";
    cout<<"\n\n\t5.DELETE STUDENT RECORD";
    cout<<"\n\n\t6.CREATE BOOK ";
    cout<<"\n\n\t7.DISPLAY ALL BOOKS ";
    cout<<"\n\n\t8.DISPLAY SPECIFIC BOOK ";
    cout<<"\n\n\t9.MODIFY BOOK ";
    cout<<"\n\n\t10.DELETE BOOK ";
    cout<<"\n\n\t11.BACK TO MAIN MENU";
    cout<<"\n\n\tPlease Enter Your Choice (1-11) ";
    cin>>ch2;
    switch(ch2)
            case 1: clrscr();
                write_student();break;
            case 2: display_alls();break;
            case 3:
                   char num[6];
                   clrscr();
                   cout<<"\n\n\tPlease Enter The Admission No. ";
                   cin>>num;
                   display_sps(num);
                   break;
              case 4: modify_student();break;
              case 5: delete_student();break;
        case 6: clrscr();
            write_book();break;
        case 7: display_allb();break;
        case 8: {
                   char num[6];
                   clrscr();
                   cout<<"\n\n\tPlease Enter The book No. ";
                   cin>>num;
                   display_spb(num);
                   break;
              case 9: modify_book();break;
              case 10: delete_book();break;
             case 11: return;
              default:cout<<"\a";
       admin_menu();
//        THE MAIN FUNCTION OF PROGRAM
void main()
    char ch;
    intro();
    do
        clrscr();
        cout<<"\n\n\n\tMAIN MENU";
        cout<<"\n\n\t01. BOOK ISSUE";
        cout<<"\n\n\t02. BOOK DEPOSIT";
          cout<<"\n\n\t03. ADMINISTRATOR MENU";
          cout<<"\n\n\t04. EXIT";
          cout<<"\n\n\tPlease Select Your Option (1-4) ";
          ch=getche();
          switch(ch)
            case '1':clrscr();
                 book_issue();
                    break;
              case '2':book_deposit();
                     break;
              case '3':admin_menu();
                 break;
              case '4':exit(0);
              default :cout<<"\a";
        }while(ch!='4');
//                END OF PROJECT
Edited by Godlygamer23
Created spoiler.
https://linustechtips.com/topic/535547-c-library-management/
https://linustechtips.com/topic/535547-c-library-management/#findComment-7104456
I have added a spoiler around your post as it was far too long for scrolling.
https://linustechtips.com/topic/535547-c-library-management/#findComment-7104556
