Posted January 27, 2016 980 rig: http://pcpartpicker.com/p/rw2QXL 980ti rig: http://pcpartpicker.com/p/8BTBwP The idea was to have a gaming/streaming build for up to $1705 that will kill 1080p and will have wattage requirements to do SLI in the future when I plan to make the jump to either 1440p or 4K. The main question is power supplies. I am planning to push the 4790k to 4.5ghz and the graphics card to the maximum 100% stable overclock. For each build I selected the PSU based on the recommendations by pcpartpicker.com, however I am not sure if that is enough based on the overclocking and extra wattage from other things. I already have a gaming mouse and keyboard (courtesy of Eagle Tec) along with the Fatality gaming headset. I would be running the system for 16-18 hours a day most of the time at idle or small load but other times on near max load. My most demanding title is the Witcher 3 which I want to run with special texture packs, shaders and also full hairworks. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2016 In 980ti everything look great but in 980 ones you should replace the PSU as it not that good(The NEX 650). I would say going with 980ti and you won't regret it. Magical Pineapples
