Hi there, I don't watercool so I don't really know much about the products out there, but I was wondering if there are CPU block and pump combo units that are equal or surpass the quality/efficiency/silence of AIO units? Thanks.
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
https://linustechtips.com/topic/535417-cpu-block-and-pump-combo/
Swiftech Apogee Drive II. It will be able to handle two GPUs.
The unit itself will product the same amount of noise as an AIO, perform the same, and the quality will most-likely be the same. One of the better CPU/Pump combos in my opinion.
blackshades on
https://linustechtips.com/topic/535417-cpu-block-and-pump-combo/#findComment-7102880
maybe one of ek's cooling kits in a box
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/535417-cpu-block-and-pump-combo/#findComment-7102893
