Need Help
Go to solution Solved by Volbet,
wireless, no switch, tried with another pc, same results, unstable
Have you tried a different ethernet cable? have you tried a different coaxial cable? If neither of these things work you should contact your ISP to hear whether or not there is problems in your area.
Yeezus was terrible, only like 2 good songs. Oh and listen to Volbeat, he knows his shit.
I don't know anything about shit, and Volbeat is a Danish heavy metal band or a bee-like Pokemon
Hey Guys, im having some ping problems with my wireless. the pings that i get are very unreliable/unstable. when i ping google.com or any other website the ping range from 50-500+ms but with no packet lose.
being a gamer this isn't really annoying.
So my question is, is there a way to fix this / do i need a new router?
and i also use this kind of cable to connect my router to the wall, not sure what its called.
http://marketingondemand.files.wordpress.com/2010/02/cable.jpg
Edit:
searched it a bit further. is it a coaxial cable? sorry if its not
Yeezus Just Rose Again
https://linustechtips.com/topic/53502-need-help/
it's called a coax cable. If possible please try to test your connection with the same computer or a laptop that shows the same symptoms with a Cat 5 cable
Error: 410
https://linustechtips.com/topic/53502-need-help/#findComment-718101
ISP, Firewall, or your router itself?
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/53502-need-help/#findComment-718102
Moved into a new house and been having the problems from the start.
Are you connected wired or wireless to the router? if you are using a switch try to go around it. If you have another computer you can try to ping that, to see if it is the router.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/53502-need-help/#findComment-718122
PC Specs:  2x GTX 550 ti in SLI - Intel i7 2600k @ 3.4Ghz - Thermaltake Overseer Case - 8 GB Corsair Vengeance Ram - 1TB Harddrive - 500 Watt PSU that came with my old prebuilt pc lawl -  ASUS P8P67 EVO
Peripherals:  Razer Deathadder Black Edition - Razer Arctosa Keyboard - Logitech G53 Headset
Cool song of the day: Chief Keef - Round da Rosey    Changed my profile pic again...                                        Mountain Dew is good. So are video games and music. Oh and unicorns.
https://linustechtips.com/topic/53502-need-help/#findComment-718126
https://linustechtips.com/topic/53502-need-help/#findComment-718134
with a cable attached its more stable, 70~76
Well, that does seem kinda high for wired, but it's definitely better than the wireless. Is the wireless device you are having problems with far away from the wireless router/access point (how good is the wireless reception)?
Do you have wireless integrated into the modem or do you use an external router?
https://linustechtips.com/topic/53502-need-help/#findComment-718141
https://linustechtips.com/topic/53502-need-help/#findComment-718152
integrated router, 5 or 6 meters away but there are no obstacles in the way. clear path
https://linustechtips.com/topic/53502-need-help/#findComment-718154
tried a new coax cable and its only changing buy 5 or so on wireless. seems to be fixed :D Thank you so much.
https://linustechtips.com/topic/53502-need-help/#findComment-718178
