Hi! I built a middle cost gaming machine (i5-4570, 8GB ddr3, GTX660Ti) and of course a new case, an Antec One and a new PSU, a corsair CX (600W). (All this for under 800$, huge step from a Q6600 and 8800GTX)
When I was assembling it, I noticed my case has a grid in the bottom, so I can put my psu facing the floor.
My question is, which way is the best?
PSU taking air from the gpu : heated air?
PSU taking air from the floor: dust?
I put it to take air from the flood, I'll keep an eye open for the dust, but I would like to hear your opinion, or advice.
https://linustechtips.com/topic/53441-wh-which-way-does-it-go/
If there is a fan filter... have it face down... if there isn't one then have it face up.
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
https://linustechtips.com/topic/53441-wh-which-way-does-it-go/#findComment-717344
do you have filters in the bottom? i have it facing down.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/53441-wh-which-way-does-it-go/#findComment-717346
facing down, looks better and better cooling for psu. if there is no fan filter get a magnetic one and stick it on.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/53441-wh-which-way-does-it-go/#findComment-717351
This is pretty much all you need to know. Dust doesn't go too well with PSUs.
https://linustechtips.com/topic/53441-wh-which-way-does-it-go/#findComment-717353
I'd have mine facing up for a simple reason, my home town has a lot of dust and the dust is rich in metal which could potentially fry the PSU if it lands in the wrong spot.
I prefer playing with heat rather than dust, dust has messed up so many computers it's not even funny.  (not mine I have a compressor in the back of my car only for cleaning my pc)
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/53441-wh-which-way-does-it-go/#findComment-717395
