RMA it or return it and buy a new keyboard
one that isnt from razer
https://linustechtips.com/topic/534186-keyboard-problem/#findComment-7088175
Basically the same thing happened to my Blackwidow keyboard but that was a few years ago now and I thought that Razer would of fixed that issue by now.
Try using it in different usb ports or a different computer and if it still does it then RMA it or return it if possible and get a better keyboard.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/534186-keyboard-problem/#findComment-7088197
