Hi everyone.
I am getting a weird sound from my machine.
It appears after somewhere between 30mins to 2 hours of moderate use, and once it starts, it gets more and more frequent to a point of almost constant 'clicking'
I got a video of it when it had been going on for 5 minutes:
https://www.youtube.com/watch?v=q0n7RxGY1-8
If I let it sit for longer, it gets more frequent and if I reboot, it continues.
It only goes away if I shut my system down and start it again.
First, I thought it might have been a bubble in the pump, but I'm starting to think it's power/static/something else since it gets more intense over time and disappears when I power cycle the system.
Anyone got any ideas? I'd love to hear some opinions and guesses before I start spending money on new coolers and fans and so on.
https://linustechtips.com/topic/533706-the-strangest-sound/
I've tried, it's rather difficult, but it sounds like its from the RAM/CPU/pump/power phases.
Definitely not the HDD's as I first expected, as I tried running the system only on the SSD and the sound still appeared.
My processor is the 5960X and ofc came without a cooler, so for me to test the cooler, I'd have to buy a new one since I don't know anyone who has a spare 2011-3 cooler lying around :P
https://linustechtips.com/topic/533706-the-strangest-sound/#findComment-7082176
It's probably the pump. Remove the pump/waterblack and put on the stock heatsink. If the clicking disappears then you know it was the pump.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/533706-the-strangest-sound/#findComment-7082199
Guess I'll have to buy a new cooler. 5960X came boxed w/o a cooler so can't test it without spending ;)
Can you borrow one from a friend?
END OF LINE
https://linustechtips.com/topic/533706-the-strangest-sound/#findComment-7082220
Coolers for CPUs are quite cheap, you are not going to spend more than like 20$ on a cheapo cooler.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/533706-the-strangest-sound/#findComment-7082373
