My first build.
Hello!
Well assuming prices translate
Also Nvidia mid range GPUs are overall a decent ammount worse than AMD's GPU, the 380 is faster than the 960, and the 390 faster than the 970, more so for higher resolutions
If prices translate 100% from germany then you can easily get an i5 + 380 for that price
PCPartPicker part list: http://de.pcpartpicker.com/p/dFYVMp
Price breakdown by merchant: http://de.pcpartpicker.com/p/dFYVMp/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (€187.84 @ Mindfactory)
Motherboard: Asus H97M-E Micro ATX LGA1150 Motherboard (€91.44 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Blue 8GB (1 x 8GB) DDR3-1600 Memory (€38.49 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€49.99 @ Amazon Deutschland)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card (€216.31 @ Amazon Deutschland)
Case: Fractal Design Core 1000 MicroATX Mini Tower Case (€40.55 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply (€77.49 @ Amazon Deutschland)
Total: €702.11
Generated by PCPartPicker 2016-01-24 14:06 CET+0100
OP appears to prefer NVidia GPUs.
No real reason to do that when you just get less performance, higher cost adaptive sync display, have less DX12/Vulkan support potentially, and have to give up your personal info for drivers
Though the 750ti is a good choice for some people, and the 950 is better than the 370 overall(though generally the /380960 even costly like slightly more and is a better choice, and of course the 980ti is the faster single GPU right now,
But in the mid range, AMD is the clear winner.
