Yo guys, wassup
Yesterday, I got a new intro template animation thingy(its for youtube) and when I started rendering it in blender it takes WAY too long. It took 2HOURS just to animate 100 frames and it still has 300 more to go. My cpu is an amd a8 7410. Is it a problem with my cpu because it took 8 hrs to render 175 frames and there are 480 frames in total.
HELP NEEDED!
https://linustechtips.com/topic/533633-rendering-problems/
Yo guys, wassup
HELP NEEDED!
are you on windows?
https://linustechtips.com/topic/533633-rendering-problems/#findComment-7081356
That sounds about normal to me. Try lowering the render settings a bit. Like remove AA and such if possible (if its even on, havent used blender that much just C4D) Oh the A8 isnt really a beast in rendering if I'm right so expect long render times. My 8350 takes years to render stuff in C4D. (1000 frames of a large model with high quality settings = 6 hours)
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
https://linustechtips.com/topic/533633-rendering-problems/#findComment-7081375
yep windows 10
go in task manager find your rendering program in there
right click
left click details
and it will take you to the details tab
right click it and change priority to very high if it asks for a password or something authenticate it
idk if windows still works like that i dont have it any more
https://linustechtips.com/topic/533633-rendering-problems/#findComment-7081383
Yo guys, wassup
HELP NEEDED!
Are you rendering it in cycles? On what resolution do you render / samples? That's quite normal especially on cpu that it takes that long. 2:45 min per frame isn't that abnormal and quite fast for cpu. with a relatively good gpu you can easily render appr 5 times faster (this is the scaling from my xeon to the 970 I use)
If you send it me, I could render it for you ;)
could do it as well ;)
EDIT: I see you are using a mobile quad core cpu... that's very normal that blender needs that long. Decrease resolution (720p instead of 1080p or even less, the pixels to render decrease with a square, so render time doubles by half the pixels -> 720p has only 1mio pixels, 1080p has 2.1 Mio)
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/533633-rendering-problems/#findComment-7081440
