Please help i was using my computer and it was working fine then it just turned off by its self and now on boot the cpu fan wont spin. I tested the cpu fan on another motherboard and it works fine.
Here is my cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113331 (Stock Cooler)
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130661&cm_re=FM2-A55M-E33-_-13-130-661-_-Product
Please Help
P.S I can boot into windows
https://linustechtips.com/topic/533613-cpu-fan-not-spinning/
It's in silent mode Kappa
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/533613-cpu-fan-not-spinning/#findComment-7081215
That won't affect on stock cooler. Or any other cooler. Silent mode only makes them spin at low speed, which is usually as low as fan can spin (400-600rpm).
Does it start spinning after you boot into windows? If not, and if any other fan doesn't work on that header, RMA.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/533613-cpu-fan-not-spinning/#findComment-7082828
