Are USB wireless cards any good? Does 2.0 vs 3.0 make a difference?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/533406-usb-wifi/
They're fine if you have to use them in something like a laptop but for a desktop, I would strongly suggest a PCI-E card.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078876
Yea I know PCI-E is desirable, but I'm trying to decide between an ITX and mATX build, and this is pretty much the deal breaker here. I'd like to avoid dealing with mini PCI cards.
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078890
Well if you can get a USB wifi with a moving Antenna
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078904
That's a thing? Can you show me some?
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078913
I have used usb wireless in the past and as long as you don't get a cheep one it should be ok, but I know people who have said they can be a bit temperamental. I have one for when I am working on other systems and cannot plug a cable in and it works just fine.
Phanteks Enthoo Evolv ATX Asus ROG Maximus VIII Hero | Intel Core i7 6700K NZXT Kraken X61 Corsair Vengeance LPX 16GB 2x MSI GTX 970 | 250GB SSD Corsair RM1000x
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078918
USB 2 and 3 does not make a difference unless you have gigabit. Also what wireless standards are you working with?
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078927
I use the Asus USB-AC56 on my desktop. Works great for me. It's USB 3.0 and I use it on an extension to place it in a slightly better spot. Cheapo USB wireless adapters are junk, but a good one should be just fine. Wireless N and below is is fine on usb2.0, but I'd get a usb3.0 adapter if using wireless ac.
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078951
I have N, but I stick to G since my connection seems more stable on it. I'm not sure if it has to do with the age of the router. I don't experience slow speeds in anything I do, including games, so I haven't bothered. I'd probably prefer to get an AC WiFi card though for when I eventually upgrade the router.
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078967
Lol, it looks funny, but I don't care as long as it works. Is it a reliable product?
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078976
This isn't actually true.
USB 3.0 is all around a better standard, and USB 2.0 can be easily saturated by even a 50/50 Mbps connection, not to mention that USB 2.0 wifi cards tend to be worse.
USB 2.0 isn't full duplex, and it doesn't support as powerful as devices (many USB 3.0 antennas have to power down to use usb 2.0 connections, like the example below.)
@OP I would highly recommend a USB 3.0 Wireless AC adapter. While such devices may be a bit more expensive now, the rate of internet speed growths and wireless standards is such that said device will work amazingly for you long down the line.
Furthermore, USB 3.0 Wireless AC adapters like this one (I used with both my laptops when traveling) http://www.amazon.com/Netgear-AC1200-Wi-Fi-Adapter-A6210-100PAS/dp/B00MRVJY1G have a much better range than many pcie variants and allow for discreet positioning if on the edge of a network (over the summer I worked in Chicago and this device was literally the difference between 30 Mbps and .1)
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7078982
Thanks. This is really good info, but that is still more than I would like to pay. Is this one any good?
http://www.newegg.com/Product/Product.aspx?Item=N82E16833315123&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7079101
So I don't know anything about that product, but in theory it should work.
The equivalent pcie add in card would be this:
http://www.amazon.com/dp/B00HF8K0O6/?tag=pcpapi-20
Also if doing an ITX system, I'd consider just getting one with wifi included.
https://pcpartpicker.com/parts/motherboard/#e=31&sort=a8&page=1&f=8
In the end it will probably be the most cost efficient option.
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7079142
Thanks for all the help guys
https://linustechtips.com/topic/533406-usb-wifi/#findComment-7079246
