Case fan speed control
Solved by WoodenMarker,
No, that has nothing to do with pwm. Pwm and voltage can both be automatically controlled and are just different ways of making the fan spin.If they are PWM they should be controlled automatically, else you ahve to buy a dedicated fan controller
Depending on the motherboard, there may be settings to control fan speeds in the bios or through software in Windows like SpeedFan.
