Help with Autohotkey
By
ROck_
in Programming
in Programming
Solved by Denned,
You would probably have to split it up. Sleep wont be understood in a sendinput command as far as I know.
Numpad5::SendInput, t/{enter}Sleep, 100SendInput, {end}{up 2} {enter}
I think that would be the correct way to do it.
toxic_worper ·
Posted in New Builds and Planning8 -
4
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
