Just got a new power supply (seasonic ss-520fl-2) and noticed a hissing which I'm assuming to be coil whine. Any fix to this? I do not want to return the power supply, so please suggest other options if possible.
Step 1. Dip it in wet concrete
Step 2. Wait for it too dry (1-2 days)
Step 3. You now have fixed coil whine!
https://linustechtips.com/topic/532650-coil-whine/#findComment-7069968
i had similar issue but with my graphics card but i just sent it away and getting a new one from evga next Wednesday if your someone like me who hates unwanted sounds coming from your computer  i would just send it back
https://linustechtips.com/topic/532650-coil-whine/#findComment-7070004
