This is my first time picking out parts to build a computer. I based it off of the $500 build in a LinusTechTips video here
but changed some stuff around to my personal taste. I plan to use this computer for gaming, programming, use of programs like Unity3d and Unreal Engine 4 to develop games, schoolwork and overall workstation.  I recognize that this isn't the most spectacular or powerful build but I want something powerful enough to be used for all of the things I listed above.
I also included keyboard with a mouse in the list. I heard that stock fans that come with the cpu are generally not that great so I chose a compatible cpu fan  (according to pcpartpicker) but there's a compatibility issue with it and the case I believe which I'm looking into and may change. I will also be doing further research into the parts later, this is just what I have at the moment.
I want you guys to tell me if this is good, or a mess of a list and to tell me what works and what doesn't work and I ask for pointers and tips for building a gaming/workstation rig.
Sorry because PcPartPicker says the build is pending I decided to copy and paste the build to the post.
CPU
f7b72284156f3602e72076645ab77238.med.256 $67.99       $67.99 NCIX US
CPU Cooler
ddea57de9797549e80d05fb3acb2e83d.med.256 $34.88 -$10.00     $24.88 OutletPC
Motherboard
de411f263d677d6017040a7e4dd9d0af.256p.jp $49.99       $49.99 SuperBiiz
Memory
b25f83905d815a40d3e6d9af557ceda6.med.256 $38.99       $38.99 NCIX US
Storage
004967848418b847790f5746581d8a65.med.256 $69.89       $69.89 OutletPC
Video Card
6633463652037f30293b23523022dcd1.med.256 $209.99 -$30.00     $179.99 NCIX US
Case
6d480deb8dbea8dd7db9a42083d8d6d2.med.256 $74.99   FREE   $74.99 Newegg
Power Supply
48a3d437b12ff7c74c4efe9ae1e51ade.med.256 $44.99 -$10.00     $34.99 NCIX US
Keyboard
046ad0174c6c8c15df610566ef5b5c14.med.256 $29.99 -$5.00 FREE   $24.99 Newegg
Base Total:
$621.70
Mail-in Rebates:
-$55.00
Total:
$566.70
https://linustechtips.com/topic/532580-my-first-computergaming-build/
$600 budget? Kay. Do you need CUDA? I assume no.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($112.99 @ NCIX US)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard  ($51.98 @ Newegg)
Memory: Mushkin ECO2 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.88 @ OutletPC)
Video Card: MSI Radeon R9 380 4GB Video Card  ($188.99 @ NCIX US)
Case: Xion XON-310_BK MicroATX Mid Tower Case  ($22.98 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Newegg)
Total: $533.79
Generated by PCPartPicker 2016-01-22 17:03 EST-0500
380 >> 960 and much better PSU.
USEFUL LINKS:
PSU Tier List F@H stats
-Snip-
The text list would´ve been just fine you know. Also, nope, not a 960. 380 over 960. On this budget, you should not be spending so much on the case. You can do better than that psu. I assume you want a black and green build?
PCPartPicker part list: http://pcpartpicker.com/p/zfwLzy
Price breakdown by merchant: http://pcpartpicker.com/p/zfwLzy/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($67.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.44 @ Amazon)
Motherboard: Gigabyte GA-F2A78M-D3H Micro ATX FM2+ Motherboard  ($56.99 @ SuperBiiz)
Memory: G.Skill NS Series 8GB (2 x 4GB) DDR3-1333 Memory  ($33.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($41.95 @ Amazon)
Video Card: Gigabyte Radeon R9 380 2GB Video Card  ($194.99 @ Amazon)
Case: DIYPC Ranger-R8-G ATX Mid Tower Case  ($48.89 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($27.99 @ NCIX US)
Total: $558.22
Generated by PCPartPicker 2016-01-22 17:08 EST-0500
Total: $533.79
He might want a black and green theme from what I can tell.
Kayfine.
Case: Apevia X-QPACK3-GN MicroATX Mini Tower Case  ($49.99 @ Newegg)
Total: $560.80
Generated by PCPartPicker 2016-01-22 17:11 EST-0500
USEFUL LINKS:
Kayfine.
Total: $560.80
His is better than mine.
Kayfine.
Total: $560.80
Okay, so I took some suggestions and updated my build:http://pcpartpicker.com/p/G2qCGX
Given your workload, as well as games making use of quad cores more and more these days, I believe that cutting down on some parts like the case and HDD to accommodate an i5 instead of the i3.
Another option, if you need the pc right now is to put the cheapest LGA 1150 CPU available in there and upgrade to something like an i7 4790 as soon as you get the chance.
Good thing is you get some upgradability even though the platform has just changed.
I managed to include an i5 in there by cheaping out on the HDD and case.
PCPartPicker part list: http://pcpartpicker.com/p/wZtcJx Price breakdown by merchant: http://pcpartpicker.com/p/wZtcJx/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($36.99 @ SuperBiiz)
Total: $609.70
Generated by PCPartPicker 2016-01-24 12:39 EST-0500
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
