im looking to buy these items for my first gaming pc(already have keyboard,mousepad,mouse and the operating system is going to be windows 7)
http://pcpartpicker.com/p/ZC94rH
any suggestions/changes i should do to this?
im going to get them from my home country, so the prices are way over that the pcpartpicker shows, so i dont have much money to upgrade anything...
https://linustechtips.com/topic/532516-need-help-with-building-first-pc/
I feel like you should drop that CPU cooler, you won't be overclocking anyways, but if you want one (or want to keep the scheme) Kyle from Awesomesauce Network did a white build and had some kind of white Enermax cooler in it that would probably work better.  You also don't need a Z97 chipset motherboard unless you plan on upgrading to an unlocked processor in the future.
I don't know about the VS series power supplies, but I have a brand bias for Seasonic.
Other than those things I think this build will be pretty solid, and that R9 390 should rock 1440p (unlike my 770 which barely gets by)
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
get a different cooler
Emanuel is almost spot on.
Its a non K CPU so just use the stock cooler that comes with the CPU.
ok im was just wondering because i have heared bad thing about the stock coolers. but anyways im thinking about the gigabyte ga-h81m-hd3 motherboard instead of the z97-p, is that any good?
