Quick Question: Will Noctua NH-D15 Fit My NZXT 410 Case?
Go to solution Solved by givingtnt,
Hello!
So, yeah, I am planning on buying a Noctua NH-D15 air cooler, or D14. But I'm not sure if it will fit my case. I have NZXT 410 case. I want an air cooler because my closed loop water cooler is way too noisy and it not even all that effective in terms of cooling. It's Antec KÜHLER H2O 950. There should be like a ~1cm of space for the D15 but I want to know if someone really knows.
And is my RAM small enough that I could use both coolers with 2 fans, my RAM is G.Skill RipjawsX 1866MHz 16Gb (2x 8Gb, DDR3).
Thank you!
yes it is compatible with nh-d14/15
ram should be fine. but its not going to much of a difference if you have one fan or 2  just get the other one in the front of the case and it will be practicly the same
Hello!
Thank you!
Hello!
Thank you!
