Power but no boot
did you sticked rams back into theyr original position? if yeas than pres the CLEAR CMOS button its suposted to be somewhere on mobo
Alright, i thank you for posting your reply. It didnt solve my problem though, but your answer lead me to finding out how to solve it though.
I booted the PC again after posting here, having the same issue. Soonafter, i reseated the ram exactly how it had been when i was having the problem, which was the same way it was seated since i got the PC from day 1.
I booted, and had the same issue. I then resorted to reseating the CMOS battery and booted up again - i then started my PC up, without putting my 970 back in, and had it boot to my second monitor. I then tried with the graphics card in again, and it did a similar issue to the beginning - but stayed on with no output to the screen.
I did another reset after that without doing anything hardware-wise, and it posted and booted perfectly fine.
