Hey guys.
I am seriously considering watercooling my system (details on footer).
Can anyone recommend a kit I can get that is decent. Not realty got a budget as not sure how much these things cost.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/531721-water-cooling-newbie/
Hey guys.
For an SLI watercooling setup your looking at around a starting price of $600 for a quality custom loop. You could get a kit say like this from EKWB and build from there by adding in extra GPU waterblocks or extra rads:
https://shop.ekwb.com/ek-kit-x360
https://linustechtips.com/topic/531721-water-cooling-newbie/#findComment-7056049
Assuming you still have a CM master case you can pretty comfortably fit a 240mm rad AIO for the CPU in there. Unless you're talking about custom cooling loops.
  • AMD Athlon X4 760K CPU   |   MSI FM2+ ATX A88X-G45 Motherboard   |   8GB 1600MHz RAM   |   MSI GTX 760 GPU (Reference)
  • Thermaltake Versa H22 Case   |   1TB Seagate, 0.5TB Hitachi (7200RPM)   |   ArcticRed+ 700WStock    |   Windows 8.1
https://linustechtips.com/topic/531721-water-cooling-newbie/#findComment-7056053
Already have an AIO so custom loop.
https://linustechtips.com/topic/531721-water-cooling-newbie/#findComment-7056253
k. Can't help you. I've been too scared to put plumbing near expensive hardware for a while.
https://linustechtips.com/topic/531721-water-cooling-newbie/#findComment-7056285
Then it pretty much custom parts not an AIO GPU kit There are tons of videos on YouTube about custom cooling - but it's pretty much GPU waterblocks, tubing, fittings, reservoir, pump, radiators, coolant and fans.
https://linustechtips.com/topic/531721-water-cooling-newbie/#findComment-7064652
