Hey Guys,
Ive streamed before using OBS but that was a few years ago, now Im encountering some problems.
I can run CS:GO fine at 200+FPS
My processor is an i7 920 @2.67GHz
and an 1GB NVIDIA Geforce GTX 650 Ti SSC for my gpu
my internet test is here
http://www.speedtest.net/my-result/5015343612
currently running obs at
2500 max bitrate
x264 encoder
base resolution 1600 x 900
downscale 1.5
filter: bilinear
FPS: 35
Tried switching between Twitch New York server and Chicago as I am based in London,Ontario
also footage saved from obs shows lag but there is some lag and tons of buffering on twitch when i monitor my stream from my ipad.
Thank you in advance for the help guys, trying to grow my stream and youtube channel ! hoping to go full-time soon enough ;)
https://linustechtips.com/topic/531437-problems-streaming/
I think you need to upgrade your CPU. Streaming takes alot of CPU power.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/531437-problems-streaming/#findComment-7050006
Try using Nvidia NVENC. It's a GPU-accelerated encoder for Kepler-based GPUs and later. My brother has used this encoder before and works.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/531437-problems-streaming/#findComment-7050010
There are GPU-accelerated encoders like the above post I have made.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/531437-problems-streaming/#findComment-7050015
What is your internet speed (up and down)
almost seems like your connection isn't strong enough toi stream at the bitrate if your getting buffering on other devices, may also be your cpu not strong enough to encode and play at the same time
Edit> sorry didn't see your results above... you definately have enough internet power, its definately cpu
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/531437-problems-streaming/#findComment-7050108
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/531437-problems-streaming/#findComment-7050179
