as long as you reassemble it in pretty much the exact same way and didnt damage anything, it should be fine.
just be very careful.
Sometimes you are able to discharge capacitors but just be careful. You took it apart fine, just work in reverse
It's safe. Most PSUs auto-drain capacitors once they are turned off. Just be careful.
Which way would the is fan go?
post-230372-0-91785700-1453345645_thumb.
post-230372-0-14063800-1453345672_thumb.
post-230372-0-35499100-1453345705_thumb.
https://linustechtips.com/topic/531402-power-supply-safety/#findComment-7049600
Okay. Can the wire go any direction as long as that sticker faces down?
I think so. Have the wire as close as possible to the fan header where you need to plug it in.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/531402-power-supply-safety/#findComment-7049775
the arrows you shown show fan blade spin direction, and airlfow direction.
depending on your preferred airflow setup, place your fans in the right direction. (generally, with the label side pointing the direction of airflow)
EDIT: most modern psus have the fan as an intake, btw.
https://linustechtips.com/topic/531402-power-supply-safety/#findComment-7049791
While sticker down is the correct answer, it doesnt necessarily teach him why. Like someone else pointed out, the arrows indicate direction of airflow and spin direction. The arrow that denotes airflow should be facing into the power supply. The fan is supposed to cool it, so it has to be set to intake.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/531402-power-supply-safety/#findComment-7050460
