Quiet LED Fans For Case
JS998
Hello :D
I don't know which fans are more quiet, Corsair AF120-LED QE or Antec TrueQuiet 120-LED or there is something more quiet on the market with red LED(fan).
Corsair fan:
http://www.amazon.de/Corsair-AF120-LED-120mm-Quiet-Airflow/dp/B00F6S0XJO/ref=sr_1_2?ie=UTF8&qid=1453318982&sr=8-2&keywords=corsair+af120+quiet+edition+red
Antec fan:
http://www.amazon.de/Antec-TrueQuiet-120-LED-Geh%C3%A4usel%C3%BCfter-Adapter/dp/B009T00ICC/ref=sr_1_1?ie=UTF8&qid=1453319228&sr=8-1&keywords=truequiet+120+red
Thanks :D
And sorry for bad English.
Hello :D
Corsair fan:
Antec fan:
Thanks :D
 A lot of builds use the Corsair ones and they seem quiet. Google a comparason.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
TNX :D I will.
Hello :D
Corsair fan:
Antec fan:
Thanks :D
Antec fans are more quiet, but also move less than 70% the air of the Corsair fans.
Where did you find this information or have you carried out tests yourself?
Hello :D
Corsair fan:
Antec fan:
Thanks :D
I've used both and the Antec was quieter. Go for the UFO edition. much sleeker design. Both editions include a toggle switch for 600rpm or 1000rpm operation. Which i found quite useful.
I pulled up specifications from Newegg.
Antec
19.9 dBA & 1.0 m3/m
Corsair
25.2 dBA & 52.19CFM (~1.478 m3/m)
It's more like 30% less or might have misunderstood how you phrased your statement, 70% less seemed unreal..
Apologies for the confusion, but the Antec does move ~66-68% (less than 70%) of the air or ~30% less.
Corsair's led fans aren't quiet whereas TrueQuiets are.
http://www.silentpcreview.com/article1480-page5.html
http://www.anandtech.com/show/9737/the-corsair-sp140-led-af140-led-sp120-af120-fan-review/5
The normal Corsair AF/SP fans are good whereas the led variants are considerably worse.
Antec
19.9 dBA & 1.0 m3/m
Corsair
Fan specs are generally unreliable and should be ignored. Stick to benchmarks and in-depth reviews instead.
TNX guys for info :D
So I should go with TrueQuiers LED or UFO edition (if I can find them) or there is something better?
Fan specs are generally open air test doesn't make them unreliable but a performance indicator. Benchmarks or in depth review which use specific test methodology are just as unreliable because performance is different from case to case.
Go for whichever looks better to you.
I can't find tests comparing the two but my initial impressions are that they are very similar if not near identical.
Testing for the specs shown on fan websites aren't standardized and can't be consistently compared.
