Help graphics card cooling
Go to solution Solved by stealth80,
Whilst I appreciate you're prob pissed I came up with a little shopping list to water cool your CPU and GPU and hence avoid your issue. I just used the EKWB shop, I suspect you can get similar products in the US for less, this whole thing includes everything down to the coolant and comes in at $425 (although for some reason its only added 2 fans, you would need 3)
Guys i need help i bought an Asus gtx980ti and one of the fans broke i sent it for rma and asus give me the middle finger saying we won't fix it. What options do i have
Motherboard: Asus Z97-Deluxe, Processor: Intel i7-4790K@4.3GHz@1.150Volts, GPU: Asus ROG GTX980 Matrix (with a NZXT G10 bracket and a nzxt x41 AIO liquid cooler), Ram: Kingston HyperX 32GB 1866MHz CL10, PSU: Corsair Hx1200i, Storage: 1TB Seagate SSHD with a Kingston HyperX Fury 240GB SSD, Display: BenQ XL2411Z, Keyboard: Corsair K70 RGB, Mouse: Razer Deathadder chroma.
pc part picker list:
https://pcpartpicker.com/user/hu0210/saved/#view=qHK6XL
https://linustechtips.com/topic/530198-help-graphics-card-cooling/
Well you could try sending it back to the retailer you got it from, or try finding a new cooler on ebay or something. Otherwise maybe someone wants to buy it off you and you could purchase a new one :/
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
look for a fan on ebay. Else, don't buy Asus
Did you contact Asus directly?
Where did you purchase it from?
If you are in the US or Canada you might want to check out this webpage:
https://cms-am.asus.com/ecp/Rma.html
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
if all else fails, you could water cool
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
did they say they wont fix it or did they say they wont fix it for free?
They said they won't fix it I said I will happilly pay for it $200 usd. They answered me we don't do it.
No i tried ording the parts once from amazon its gets stopped in customs and if it does pass through cargo is so damn rough the parts are all broken when i open the box.
How did the fan break? Which GPU is it exactly?
Yes i contacted asus directly and payed for the courier charges myself. They told me we don't do this kind of job sorry. I purchased it from a computer center 20 minutes drive from where i live. I took it back to the shop. One bitch he told me buy a new graphics card this one is gone
I guess it's time to do or die I'm going to try and ghetto rig a cooler corsiar h80 to the gpu. It seems i am alone on this one. Thanks for the help guys i really apreciate. It just makes me angry how they treat me like this after spending so much money.
Is it your fault that the fan is broken?  I can totally understand them not wanting to fix it if you broke it.
Ryzen Ram Guide
At least they could try something they could try to water cool it or something instead of telling me no go away and buy a new one.
I'm going to try. I think that water cooling is the best solution for the graphics card. Thank you and god bless all you guys for helping out.
