right guys i have this weird scratching/buzzing noise hard to explain the sound but after taking out the back case of my computer i put my ear next to the cpu from the back and it sounds like it coming from there i dissconected the fan for the cpu block and it still continues to make a noise if took out all my other fans and replaced my graphics card to test if its still there and it is any suggestions
https://linustechtips.com/topic/529965-weird-noise/
Can have more details?
It could be a case fan or something, it could be coil whine...
Sig under construction.
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031369
Are there any hdd's you have left plugged in?
Moved to General Discussion.
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031370
Could be your power supply or even just the mobo as a whole.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031379
Check for any live animals behind the motherboard tray.
CPU: Intel Xeon E3 1231 V3 3.4ghz CPU COOLER: Cryorig H7 w/ Red Corsair SP120mm  MOBO: MSI SLI Krait Edition Z170 MEMORY: G.Skill Ripjaws 8gb (2x4) Storage: Kingston V300 120gb, WD 1TB GPU: MSI R9 390X CASE: Phantom 410 (ew) PSU: Thermaltake Toughpower Modular 550w CASE FANS: 4 CORSAIR SP120mm MONITOR: LG 25UM67 KEYBOARD: Das4 Ultimate Cherry MX Blue MOUSE: Deathadder Chroma Left-Handed AUDIO: Sennheiser HD598 Black, Astro A40s
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031388
my cat went missing month ago sadly it wasent him making the noise
I think it's coil whine from your PSU
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031438
My mother board is over 4 years old many hours racked up on it
It could be it. Not saying it is. I've had some mobos with almost 10 years of constant use on them that squeal like pigs, and others that don't do dick.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031642
well that was not a turn that i expected
QUOTE when replying to others / Quality over Quantity in your posts / Avoid ambiguous topic titles
Desktop: "Shockwave" Core i7-5820K / GTX 970 SSC / ASUS X99 Deluxe / 16GB DDR4 / 120GB Samsung 850 EVO / 2TB WD Black Caviar
Laptop:  "Archippos"  Dell XPS 15:  Core i7-7700HQ  /  GTX 1050  /  16GB DDR4  /  512GB NVMe PCI-E SSD
https://linustechtips.com/topic/529965-weird-noise/#findComment-7031694
so every fan is disconnected and the noiseis not coming from the HHD and the ssd there are no wires touching fans or anything its really hard to narrow down where about this noise is coming from
Did you disconnect your hdd's?
https://linustechtips.com/topic/529965-weird-noise/#findComment-7032893
