First PC Build
I am planning on building my first PC in the next few months and it will be used for gaming for the most part. I am having a hard time deciding on two different builds, which are both around
If you're going to be streaming then ya the 8 cores can come in handy, but you can't buy a low end motherboard with AM3+
You're looking at something like this spending more on the power supply if you have it for a bit more stable OC
Overclocking Guide
http://www.overclock.net/t/1348623/amd-bulldozer-and-piledriver-overclocking-guide-asus-motherboard
8320E Gaming Benchmarks
http://www.anandtech.com/show/8864/amd-fx-8320e-cpu-review-the-other-95w-vishera/5
PCPartPicker part list: http://pcpartpicker.com/p/QKh2vK
Price breakdown by merchant: http://pcpartpicker.com/p/QKh2vK/by_merchant/
CPU: AMD FX-8320E 3.2GHz 8-Core Processor ($119.99 @ NCIX US)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard ($116.97 @ OutletPC)
Memory: G.Skill Value Series 8GB (1 x 8GB) DDR3-1333 Memory ($33.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card ($203.98 @ Newegg)
Case: Deepcool TESSERACT WH ATX Mid Tower Case ($42.98 @ Newegg)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($38.47 @ OutletPC)
Total: $606.36
Generated by PCPartPicker 2016-01-18 16:23 EST-0500
