OS help
Go to solution Solved by Tomic,
@Tole2378 move anything really important from the drive to somewere and formatte the drive with vista it then boot your pc from the dvd of Windows then follow on screen instructions
Have windows 8.1 on a USB Bootable drive and boot from the device to install windows 8.1.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/529198-os-help/#findComment-7021611
Red Fury: Cpu intel i5 4960k GPU 1060 6gb, Cooling  noctua dh15 storage 1tb sshd 250gb ssd mobo gigabyte z97p-3 case fractal r4 ram hyper x fury red 8 gb psu 550w xfx ts os win 10 monitor lg 25um56
https://linustechtips.com/topic/529198-os-help/#findComment-7022079
