I bought a 5850 that had been voltage modded with a "trimpot" (a variable resistor, that you can adjust to change voltage on the card)
Before turning it on, I measured resistance on the trimpot, and found the correct direction to turn the wheel. I turned it to the higher resistance side, to make sure the gpu wouldn't get crazy volts on boot.  Higher resistance = less volts
It has no display output, v core voltage reading shows 1.14v from a digital multimeter when inside windows, but no display output.
The vrm heat up, so they're definitely receiving current...
I tried dvi port, and display port. But nothing, just black screen entire time. Tried clearing cmos as well..
Any other troubleshooting I can do? Or is it dead?
I booted into windows with IGPU, and the 5850 was recognized, but it doesn't seem to be recognized now.
https://linustechtips.com/topic/528898-5850-no-display-output/
