was playing rainbow six siege and it froze so I had to force shutdown. When I rebooted, my desktop icons had a pink streak through them and my mouse was unavailable. This persisted every time after booting though there were a few times where I could use chrome for around 5 minutes before it failed. I restarted the PC in safe-mode and used DDU to get rid of the drivers and then I reinstalled and I also did a windows update. This error has now been delayed everytime I open my desktop however right on startup I get the notification (disply driver has stopped and recovered...). Can somebody please help me and suggest fixes or tell me if something is fried due the unexpected shutdown?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/528874-need-help-pc-broken/
It's sound to me like something has gone wrong with your GPU, do you have a spare GPU that you can try or maybe just try using onboard graphics to see if it still does it? Also make sure to follow your post :)
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/528874-need-help-pc-broken/#findComment-7017894
I have tried using the onboard and it seems to work, but my GPU is also working right now because I typed this thread while on it.
https://linustechtips.com/topic/528874-need-help-pc-broken/#findComment-7017902
Then something may have happened to Windows or your HDD (unlikely but possible it was the drive) when you had to force shutdown. I had a problem similar to this once but I didn't have any issues with the screen. My PC just randomly stopped playing some games after having to force shutdown, the only way I ended up fixing it was by reinstalling windows, maybe you can just try Windows repair off a boot deivce first and if worse comes to worse a reinstall might be the best option to try and repair it.
https://linustechtips.com/topic/528874-need-help-pc-broken/#findComment-7017912
Windows repair didnt work so I went ahead and reinstalled windows (keeping personal documents) and it seems to be working again. Im almost positive somehow windows became corrupted because after taking a closer look at it, the red boot device LED was on everytime I recieved that error and at one point an audio loop began and the PC froze. After cleaning up the entire PC it seems to be properly working but I will post updates if I need further help. Thanks I appreciate your time!
https://linustechtips.com/topic/528874-need-help-pc-broken/#findComment-7018088
No problem! :D
https://linustechtips.com/topic/528874-need-help-pc-broken/#findComment-7022465
