BIOS Setting Help.
Solved by Immrspy,
Figured it out. The Power Supply on the HP Pentium P-6 is only 300 Watts, and it is sadly not enough. Changed the power supply, and it works fine now. Thanks for all the help!
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
