So I bought a 500GB 850 EVO to upgrade from my 240GB Kingston V300 as my boot drive. Is it possible to do a fresh install on the 850 and then allocate it as main drive and remove windows from the Kingston, and copy all other files onto the 850, because I have a lot of programs and BF4 installed on the SSD and would hate reinstalling everything.
https://linustechtips.com/topic/528771-help-with-migrating-boot-ssd/
I did this when i went from a 128gb a-data ssd to a 500gb samsung m.2 drive. I believe the way i did it was with Aomei backupper http://www.backup-utility.com/free-backup-software.html I believe the way i did it was making a backup of my ssd and then installing it to my new ssd and then turning off pc and switching them out. I think that worked for me, don't remember if there was any other steps.
Actually i reinstalled Aomei to look at it, go to clone and click system clone. normally it's locked, to unlock it just wants you to share a post of Aomei to twitter.
Hmm but that's like a clone, right? I have had issues with clones before, so I don't think I want to do that. Worst comes to worst, I will do a fresh reboot.
Thanks for the info though.
I've tried a few programs before i came across Aomei, a lot of them being slow as balls or just don't work right, but Aomei seems to be a good one and I haven't had any issues with them. With the system clone you just need to have both drives installed in your pc and then clone your system on your main drive to the new one, then power off and remove your old drive, make sure to set the new drive in the boot order in bios
So would I still be able to format my old drive and use it for installs/storage?
clone the kingston to the samsung with acronis trueimage
then format the kingston
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
yes.
both methods work i guess, although i think Acronis was one of the things i used before and it was pretty slow.
Or use Samsung's very own Cloning software...for his Samsung 850 EVO SSD...because the software is written for Samsung SSD's...
If the OP purchased a retail Samsung SSD, the cloning software is already included in a DVD. Otherwise, he/she can download the software directly from Samsung.
My two cents.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
My two cents.
b-but... my... advice...
I ended up using Acronis, and it worked excellent. Thanks for the advice guys.
My two cents.
I wish I knew this earlier. I bought an M.2 850 EVO, so no CD came. Still, thanks for the advice and Acronis worked just fine. I will know for next time.
