I'm having some trouble with unstable connection to internet using a wifi adapter for my new budget pc. I can't use ethernet directly to my router since the router is too far away. My question: can i connect an ethernet cable from my budget pc to my laptop (which has much more stable connection) in order to have better internet?
thanks,
ethan
https://linustechtips.com/topic/528618-ethernet-help/
hmm no? i think
CPU i5 6600k 4,4Ghz , COOLER Dark Rock 3 from BQ, RAM 16 GB of ddr 4 2800MHz from corsair,
 PSU EVGA 750 W GOLD G2, MOBO Msi z170A Gaming M3, CASE NZXT H440 Black/Blue,
GPU Geforce GTX 980 Gigabyte G1 Gaming,
STORAGE 1 SSD Samsung 850 Evo 250 GB and 1 HDD 500GB WD, Windows 8.1.
https://linustechtips.com/topic/528618-ethernet-help/#findComment-7014633
You can try powerline?
But in reality running Cat5e is really cheap.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/528618-ethernet-help/#findComment-7014636
If you bridge your laptop's wifi and ethernet connection, you can connect your laptop and desktop together with ethernet.
CPU: Ryzen 9 5900X @ 4.7GHz | GPU: EVGA RTX 3080 | Motherboard: X570 I AORUS PRO WIFI | RAM: G.SKILL Trident Z RGB 32GB | Case: NCase M1 v6.0 | SSDs: Samsung 970 Evo+ 1TB, 860 Evo 1TB | CPU Cooler: H100i ELITE CAPELLIX | MonitorsLG 27GN950-B 4K 165Hz |
https://linustechtips.com/topic/528618-ethernet-help/#findComment-7014940
