I have a wall-mounted 4K TV with the HDMI outputs at the back, we managed to get an HDMI cable put through the wall and come out through a socket, but we can't access the others. Since we need multiple sources, is there a hub (don't know if terminology is correct) that can display 4k and have multiple outputs we can switch between, preferably a good brand so that it doesn't break :) Any help would be appreciated, preferably along with the price in GBP (although that i can check myself)
Thanks
CPU: Intel Core i5 4690 3.5GHz
Motherboard: Asus Z97-P DDR3 ATX
RAM: Kingston HyperX Savage 8GB 2400MHz
GPU: Palit Geforce GTX 1060
Case: Zalman Z9+
Storage: Seagate Barracuda 2TB 7200RPM HDD, SK Hynix 256GB SSD
PSU: SuperFlower Golden Green HX 550W
OS: Windows 10 64-Bit
https://linustechtips.com/topic/528567-need-an-hdmi-hub/
I have a wall-mounted 4K TV with the HDMI outputs at the back, we managed to get an HDMI cable put through the wall and come out through a socket, but we can't access the others. Since we need multiple sources, is there a hub (don't know if terminology is correct) that can display 4k and have multiple outputs we can switch between, preferably a good brand so that it doesn't break smile.png Any help would be appreciated, preferably along with the price in GBP (although that i can check myself)
Thanks
Have a look around on Amazon. I found one that actively advertises having 4K support here:
http://www.amazon.co.uk/CSL-bidirectional-Full-HD-Frequency-capable/dp/B00W6XRCKA/ref=sr_1_13?s=electronics-accessories&ie=UTF8&qid=1452975232&sr=1-13&keywords=hdmi+switch&tag=linustechtips-21 (£9.85) with solid 5 star reviews.
I personally wouldn't pay anything less than 5 quid for a decent splitter.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/528567-need-an-hdmi-hub/#findComment-7014082
