CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($62.98 @ Newegg)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  ($308.98 @ Newegg)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($50.99 @ SuperBiiz)
Wireless Network Adapter: Belkin F9L1001 802.11b/g/n USB 2.0 Wi-Fi Adapter  ($8.99 @ Amazon)
Total: $746.69
Generated by PCPartPicker 2016-01-15 21:48 EST-0500
Switch the XFX for a PColor and the case to something cheaper if you want.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009033
I'd invest in a quad core CPU for gaming. Change the GPU to a R9 380. Added a SSD and a better case:
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.88 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($183.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Directron)
Total: $712.48
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009035
I don't really recommend getting ASRock Boards... had alot of problems...
This is just a gaming build, you can overclock the G3258 to 4.0GHz with stock cooler and probably around 4.5GHz on liquid cooling
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($66.99 @ SuperBiiz)
CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler  ($77.99 @ Newegg)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($90.88 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.98 @ SuperBiiz)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($34.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($38.98 @ Newegg)
Total: $718.77
Generated by PCPartPicker 2016-01-15 21:50 EST-0500
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009039
Total: $712.48
But... A 390...
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009041
Total: $718.77
Bad CPU, bad PSU. Bottleneck inevitable.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009046
PCPartPicker part list: http://pcpartpicker.com/p/KjfkVn
Price breakdown by merchant: http://pcpartpicker.com/p/KjfkVn/by_merchant/
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($88.75 @ OutletPC)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: Sapphire Radeon R9 380X 4GB NITRO Video Card  ($233.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.88 @ OutletPC)
Total: $771.44
Generated by PCPartPicker 2016-01-15 21:51 EST-0500
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009051
But... A 390...
But...a Samsung 850 EVO :D
Anyway, I've gone for a $700 build, so OP can pick yours if he's willing to spend more.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009060
Overclock m8?
Yeah. No. That's not going to magically make a dual core become a quad core.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009082
OP hasn't state what games he will be playing, but ok... is he going to be playing Crysis 3 on Ultra Settings?
Edit: Quad Cores are nice. and Octacores are like boobs.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009104
No game will run better on a Pentium than on an i5.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009115
Overclock m8?
Only two threads and two cores. Games like GTA V only like to run on four cores.
Performance of the stock i5 will also do better than the OC Pentium in quite a few games:
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009121
As long as I can play most games at minimum or medium graphics at above 30 fps I'm fine
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009133
Also, I'm fine with and cards but I prefer Nvidia
If it's one price point AMD dominates at, it's the R9 380 vs the GTX 960. Much better performance than it's NVIDIA counterpart.
It's more debatable at the 390/970's price point, but you're not going to easily find a GTX 970 that's cheaper than the R9 390 in America.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7009202
Yeah, that's fine.
https://linustechtips.com/topic/528110-help-on-a-gaming-build/#findComment-7011000
