If my PC uses 300W, it means that it uses 300W per hour right?
So if I compute the impact on my electric bill it will be..
0.3 * (Hours of use per day) * 30 * (Price per kwh) = Monthly Bill
Please educate me if there's something wrong. Thanks a lot!
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/527653-power-consumption/
No, it just uses 300W. If it were running for an hour, then it would come out to be 300Wh.
https://linustechtips.com/topic/527653-power-consumption/#findComment-7002837
Oh yea im a little sleepless. Lol But still my formula above is correct right? That's how I will compute the impact of my pc on the monthly bill.
https://linustechtips.com/topic/527653-power-consumption/#findComment-7002857
http://www.rapidtables.com/calc/electric/energy-consumption-calculator.htm
This should help you out :)
kWh*price/kWh=cost of running your PC.
Hope this helps :)
EDIT: So yes, looks like you're right to me :P
https://linustechtips.com/topic/527653-power-consumption/#findComment-7002876
