Hey guys, wanted to ask if this build was good enough to be superior to the ps3/xbox 360. He wants to play games like TF2, Gang Beats, L4D2, Binding of Issac, Battlefront 2, Day Of Defeat, GMOD, and Quake live. I was wondering tho, can this play games like Gta v, and fallout 4 at Low to mid settings at 30+ fps at 1080p or 900P, what about 2 player Rocket League at 1080p mid to high settings over 30 fps? Also, since were on a budget under 500, is it good? or do i have more options, im looking for quality and cost. We want it to fit onto of the desk that comes with a bunk bed he has, Probably not more than 10 feet long in distance. We have a monitor, we just need a keyboard and 2 game pads, so we can play Gang Beats and Rocket Launcher together from time to time, i also have a friend that will pitch in windows 10 for 20 bucks :) Thanks In advanced!
PCPartPicker part list: http://pcpartpicker.com/p/mBv2hM
Price breakdown by merchant: http://pcpartpicker.com/p/mBv2hM/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($66.99 @ SuperBiiz)
Motherboard: ASRock B85M-ITX Mini ITX LGA1150 Motherboard  ($47.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  ($38.50 @ Amazon)
Video Card: Asus Radeon R9 270X 2GB DirectCU II Video Card  ($184.99 @ SuperBiiz)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($34.99 @ Micro Center)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Newegg)
Other: Linksys Powerline AV 1-Port Network Adapter Kit (PLEK400) ($40.95)
Total: $504.37
https://linustechtips.com/topic/527529-steam-like-machine-mini-itx-build/
Be sure to turn off your PC before doing this:
Step 1. Unscrew side panel
Step 2. Remove aforementioned side panel
Step 3. Remove the screws that hold the power supply in place
Step 4. Gently unplug and carefully undue wires and cable management that involves cords connected to the power supply
Step 5. Once completely unconnected from your PC, remove power supply
Step 6. With great control and carefulness, smash power supply over cinder block with sledge hammer, Gallagher style
Step 7. Using an other internet connected device, access your preferred computer component merchant
Step 8. On your website of preference, navigate your way through until you find an EVGA G2 of B2 power supply of efficient wattage, or another brand of reputable quality
Step 9. Order power supply
Step 10. Allow time for shipping
Step 11. Upon arrival, remove power supply from box
Step 12. Install power supply
Step 13. Return removed screws
Step 14. Plug in cables
Step 14. Redo cable management
Step 15. Return side panel back to case
Step 16. Screw in side panel
Step 17. Turn on your PC and hope it boots properly
Congratulations! You have officially rid your computer of cancer.
https://www.youtube.com/watch?v=dYHVUrXOwbI
Thanks...
-snip-
It will crush all the games you mentioned at max. No worries about that. Change the PSU
EDIT, reread the post Kappa.
WOnt run GTA, id recommend upgrading to an i3 with hyperthreading for that.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
Sorry for being really bad at this, I'm fairly new, and i3 recommendations?
Humm, depends on your budget really :I
Also the AMD athlon x4 860K will do a good job at it - Didnt remember this one when i mentioned the i3s. Its cheap and very cost effective.
Thanks...
Lol sorry, but seriously stay away from CX psu's.
But seriously, I urge you to save a little more and get this. It will be worlds better, trust me.
PCPartPicker part list: http://pcpartpicker.com/p/hxP7mG
Price breakdown by merchant: http://pcpartpicker.com/p/hxP7mG/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($68.99 @ NCIX US)
Motherboard: ASRock FM2A88X-ITX+ Mini ITX FM2+ Motherboard  ($81.98 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.88 @ OutletPC)
Video Card: Sapphire Radeon R9 380 2GB ITX Compact Video Card  ($198.98 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($42.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($26.99 @ NCIX US)
Total: $626.74
Generated by PCPartPicker 2016-01-14 23:36 EST-0500
Lol just finished a build for him with the athlon
Total: $626.74
Hmm, 100 over budget, Seems alright tho, can I run the games I said like I said? What about gta ...
YOu will be able to run GTA 5 just fine in mid settings.
