so I noticed that my 850 Pro was getting pretty hot in the right chamber of my Air 540. There is no airflow in that section and there is a ventilated area in the back and I was wondering if I could put two or three 92 or 80mm fans where those vents are exhausting air.
https://linustechtips.com/topic/526807-air-540-cooling/
@MacAlisterL
Same case. My evo is sitting at 32* now. 7* warmer than my Pro in the main chamber. I keep in mind that laptops damn near cook SSDs. I believe as long as it's not over 50* for extended periods, it's fine.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/526807-air-540-cooling/#findComment-6992479
I have four ssd stacked back there and three hdds in the 5.25's bays and they never see over 40.
https://linustechtips.com/topic/526807-air-540-cooling/#findComment-6993410
What are your temps?
https://linustechtips.com/topic/526807-air-540-cooling/#findComment-6994322
