workstation as in?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Thats actually a horrible work station
Storage wise and memory choice wise, Prob GPU wise to since someone would prob use a quadro
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
^this
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Im not buying a PNY M6000 12 GB card. and I am going to run multiple OS's.
still horrible...
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Im only going to spend around 6k
what are you gonna do with it?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
where did all the money go? O.o
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Its going to be a workstation, part bitcoin miner, and video edting. I plan to keep the CPU's and coolers and the motherboard
"workstation" doesnt mean anything. at all.
1. Bit coin mining is dead, deal with it. period.
2. Why would you want two 4core CPUs? Why would you want this overprices motherboard? Why would you want the coolers?
Thats all BS.
3. Why for fucks sake 3x 32gb ram? 3?
4. 1600w PSU? For what?
Here's what i would do:
1. Consumer Grade but professional CPU, i7 5960x $1000
2. Consumer grade 2011-3 motherboard $250
3. a quad 32gb ram kit. more than enough. $250
4. 2x 980ti if you feel like it although you probably won't need them, a single one will do. $650 or $1300
5. a 850 watt PSU for sli 980ti. $150
-> Profit because much cheaper.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I
Thats all BS.
First of all im going professional so i need the professional materials and im going to do server grade programs that's why
I
go with something like this, will suite just fine for less moneys.
http://pcpartpicker.com/p/XnMT6h
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
first of all i prefer a dual CPU config.It has a higher voltage per core which is better and like i said i prefer Xenon's because of its server-like standards. Second why not dave ram room and pay a bit more for 1 stick instead of 4 and save room for upgrade ability?
Why would that be better in any way?
Is that thing running 24/7? If so, oh yeah, the i7 will still do. But you can buy an 8core xeon for double the price if you want.
Because quad channel doesnt work that way and the motherboard i selected still has 4 slots free so you could go 64gb.
and did yo not hear that im running multiple operating systems?
aaaaand? You can't do that with this system because?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
What? Unless you need the features of a Xeon it's the same.
The way I see it is having 2 quad cores gives more failure points than a single 8 core i7/Xeon, wastes power and costs more.
2500K @ 4.5GHz | ASRock P67 Extreme 6 | 16GB Ram | GTX 750 Ti | 250gb SSD | 1TB+2TB HDD | 720W CoolerMaster PSU | Essense STX Sound Card | Define R5
Problem is is that an 8 core xenon has a 1.6 base clock rate i prefer using a little more wattage
It's not Xenon, it's Xeon. You can get high clocked ones. What features do you want on the Xeon that the i7 doesn't have?
that sentence made no sense. at all.
How old are you m8?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
